On a ride yesterday my cadence readings started to get very erratic and high (like over 500PRM). This morning I installed a new battery in the cadence sensor and re-paired it. Still the same results. Any ideas?
Larry
Wackey Cadence readings
Re: Wackey Cadence readings
You are probably getting double hits on the cadence sensor. Try moving the sensor OR the magnet slightly away from each other.
Also, if you have your speed and cadence magnets in the same general area the speed magnet may be ending up too close to the cadence sensor.
Thanks Fernando. Moving the sensor a bit further from the magnet did the trick.
