Battery not holding a charge for long
longinthetooth
Post by longinthetooth »
Can the iBike Newton battery be replaced?
I'm finding that it isn't holding its charge very long. Being holiday period I haven't ridden as regularly as usual, and am finding that has discharged in a week of no use from a full 100% to zero!
Postage to and from Australia to the USA for every issue is significant!
Re: Battery not holding a charge for long
The Newton will discharge naturally when not in use.
Make sure that you have firmware 413 installed, then completely charge the unit. It most likely is OK.
