unit screen desired in setup mode
donnybike
Post by donnybike »
It seems the unit screen disappeared in setup mode.
I use english unit most of the time.
But sometimes I need to change to metric to do field tests,
Such as 5 km all out test.
Some important field tests are designed as km rather than mile.
Right now it is impossible to change it in the field.
To change it, we have to use fast start with issac,
Which alters the existing profile in ibike.
Or did I simply miss the unit in setup mode?
Re: unit screen desired in setup mode
It's where it always has been!
Go to Fast Start. Select Yes. Click the up arrow.
The first item in the sequence is Units, where you can select between english and metric.
