Gps merge with Newton from Edge 520
Postby texmurphy » Sat Jun 17, 2017 2:58 pm
I have not had any problems merging the timing and gps coordinates from my Garmin Edge 500 .fit activities using Isaac with Newton datasets.
I have just switched to an Edge 520 and now the gps merge fails in Isaac.
Using Edge 520 firmware 10.00 (came installed with the 520) the merge operation fails with a Labview Memory Full error.
I downgraded the 520 to firmware 9.10 and the merge operation just ignores the .fit data from the 520 (no Labview error and shows only iBike data on the charts).
Using Isaac for Windows v4.1.0
Parallel device recording with the old Edge 500 with the 520 will successfully merge the Edge 500 .fits to Newton recordings.
Does Isaac need to be updated to support the latest .fit formats?
Will I need to convert the 520 .fit's to tcx?
texmurphy
Re: Gps merge with Newton from Edge 520
Postby Velocomp » Sat Jun 17, 2017 3:17 pm
I think the .fit format has changed, but if you use tcx it should merge.
Return to Isaac software
Who is online
cron
