Feature request: calendar view
ronpei
Post by ronpei »
it would be really great if you could see a monthly calendar with days highlighted that have ibike data so that you could click on the date and up load a specific ride. Right now i is not user friendly to find a ride and I end up using other software to record and review my data.
Re: Feature request: calendar view
Agreed.
Pete
Post by Pete »
Perhaps with optional text/note to remind what the ride was?
Some other ideas:
Access the 'download single ride' wizard direct from Isaac toolbar
Ability to auto-delete single rides as they are downloaded via above wizard
Be able to set default settings (ie to apply when dowloading multiple or single rides)
eg
"Did not ride with Newton Tracker"
"Ride ended where it began"
"Wind Changed"
& any other 'route analyze' settings
Currently I need to manually select the above for each ride.
Or maybe this can be done already?
Pete
Post by Pete »
Pete wrote: Be able to set default settings (ie to apply when dowloading multiple or single rides)
eg
"Wind Changed"
^ So I guess these could be added as selections to "Edit/Preferences/Analysis/Automatically Analyze Route"
