indoor trainer with wired ibike pro
Bike4Him
Post by Bike4Him » Tue Oct 04, 2011 9:24 pm
I am upgrading to a pro from iSport.
It is wired.
Would it work to buy another wired mount and use a wired version with an indoor trainer.
Speed sensor on the back wheel and the mount on top tube or somewhere.
I realize I would have to purchase the trainer key.
And. Does the trainer key work with rollers?
If this info has been discussed before please send me to the proper thread.
Re: indoor trainer with wired ibike pro
Post by racerfern » Wed Oct 05, 2011 12:36 am
Assuming you're using a different bike for the rollers, then yes, a separate wired mount makes sense. Although I'm not sure if they're still available. Check the store or send velocomp an email. If all else fails, I might have one which I used once or twice before going wireless.
The trainer key will work with rollers. Look in the iBike software for a match to your rollers.
Bike4Him
Post by Bike4Him » Wed Oct 05, 2011 10:51 pm
racerfern wrote:Assuming you're using a different bike for the rollers, then yes, a separate wired mount makes sense. Although I'm not sure if they're still available. Check the store or send velocomp an email. If all else fails, I might have one which I used once or twice before going wireless.
Thank you for the reply. I've sent an e-mail via the website but it comes back non-deliverable.
There are none available in the store.
If you find an extra mount let me know.
Morocco Mole
Post by Morocco Mole » Thu Oct 06, 2011 7:44 pm
Bike4Him wrote:I am upgrading to a pro from iSport.
It is wired.
If your brave, careful and handy with a soldering iron you can extend the sensor cable so you can still mount it on the bars or stem. I had an old cheap cateye computer lying around and the cable used was identical.
Bike4Him
Post by Bike4Him » Fri Oct 07, 2011 2:15 pm
It is wired.
A friend offered to install a removable wire coming from the existing wire. This way I can install a temporary sensor to the back for trainer use.
Thanks for the idea.
