Speed sensor not responding
Hey everyone, so I finally installed the isport and everything was going fine until I tried to get a speed reading during the initial setup. I have the magnet passing within a couple of millimeters from the sensor and I have tried removing the battery and reinstalling it, but still no reading. I do have another magnet located on the left side for a computer that is currently mounted, but I wouldn't think that would cause a problem with the isport sensor. I do have a wired isport by the way. Could I have a bad sensor? Hopefully it is something I'm just overlooking, but I'm not sure what else to try. Any help would be greatly appreciated.
- Morocco Mole
Re: Speed sensor not responding
Can you hear the faint click from the sensor as the wheel magnet passes? You will need to do this in a quiet location but it will tell you if your have the magnet sensor positioned correctly. Also, inside the sensor there should be a switch than changes it from a Cadence Sensor to a Speed sensor, check you do not have it around the wrong way.
