iSport Wireless Install Problem
Q&A for all things iSport
Postby doofus » Thu Sep 03, 2009 8:45 am
I'm having problems with step 15 on "Install Wireless Mount and Sensors" (firmware 402+, August 2009).
1) mount on stem, iSport securely in mount.
2) cadence sensor is on non-drive stay, pointing up, about 4cm from the BB
3) speed sensor is on the drive stay, pointing up, about 8cm from the BB.
batteries are the ones that came with the units yesterday.
when I wake up the iSport by pressing the center button, "AutoWind" appears. When it is finished, it goes to the speed display. No readings from the sensors, and WLS/pairing screen doesn't appear.
did I goof something?
what's the fix so I can set it up and get the cal ride done?
doofus
Re: iSport Wireless Install Problem
Postby coachboyd » Thu Sep 03, 2009 8:55 am
Go into the setup screen, scroll to 'scan' hit the center button and it will look for your sensors. Make sure you are wearing your HR monitor or else it won't be picked up.
coachboyd
Postby doofus » Thu Sep 03, 2009 9:03 am
there's no HR strap
I ordered the wireless sport and the optional cadence sensor
do i need to start cutting zip ties and throw it in the box until I get a HR strap?
the instructions don't say anything about going to the setup screen or how to get there
doofus
Postby coachboyd » Thu Sep 03, 2009 10:15 am
Hold the top button for two seconds to enter the setup screen, then you can scroll to the 'scan'. If you don't have a HR monitor,then it won't find one and you'll be good to go without heart rate.
Here's the instructions for firmware 4.02. I HIGHLY recommend reading through these. It will answer 99% of the questions
viewtopic.php?f=12&t=1191
coachboyd
Postby doofus » Thu Sep 03, 2009 11:49 am
thanks boyd
the sick thing is I read the pdf first
(i can manufacture confusion from clarity with ease -- see the near-crash before the start of french broad back in july)
doofus
Postby doofus » Thu Sep 03, 2009 8:36 pm
yeah, go it working fine
did a 2hr ride with 90min tempo
245 avg for the ride, consistently around 275 for the tempo
those numbers jibe with the 330FTP from computrainer sessions this summer
400 bucks, and even a doofus can figure it out
pretty cool
doofus
Return to iSport
Who is online
Users browsing this forum: No registered users and 2 guests
