iBike Aero III w/Garmin speed cadence sensor issue
ScottChapman
Post by ScottChapman »
So, my unit is suddenly showing me calories instead of cadence. I know the speed/cadence sensor is working because of the wattage it is showing me only when I pedal.
Any ideas (sorry if this is a FAQ, couldn't search for it).
Re: iBike Aero III w/Garmin speed cadence sensor issue
If it shows calories that means the cadence sensor isn't registering anything. Make sure your cadence magnet is passing close to the speed/cadence sensor. If you wave a magnet past the cadence sensor and the sensor is working, Cal will covert over to RPM.
Also make sure that under the RACR menu you have CAD set to ON, otherwise you get HR and Cal.
ScottChapman
Turns out it was the the Garmin Speed/Cadence sensor on the blink. Replaced it all good now.
