HR fail after installation of Cadence sensor
I just installed the wireless sensor (I already had the wireless speed sensor and HR strap). The cadence sensor paired and worked perfectly. The problem is that now it does not recognize the HR strap any longer. I went into WLS CFG and set all three to FIND. The speed and cadence re-paired beautifully, but the HR wont pair. No WLS FAIL, just nothing. Interestingly enough, the HR strap pairs with my Garmin Forerunner 405 just great. Any takers?
Re: HR fail after installation of Cadence sensor
That's weird for sure. Remove the battery in the HR Strap, flip it over for a second then reinstall it. That will force a new pairing code. Now try finding again. But note that you will have to set your Forerunner 405 to search again because it's looking for the old pairing code.
I took the battery out of the strap for an hour, reinstalled, then re-paired. Everything worked fine. I think benlane is on to something. Thanks for your help.
