Remote Wind Sensor Instructions
Postby Velocomp » Tue May 05, 2009 12:26 pm
Updated January 2016
NOTE: ON NEWTONS WITH THE GREEN WIND VANE, REMOVE THE WIND VANE BEFORE INSTALLING THE REMOTE WIND SENSOR!
RemoteWindSensor012616_red.pdf
(471.3 KiB) Downloaded 54 times
Re: Remote Wind Sensor Instructions
Postby mccork » Wed Feb 17, 2010 12:55 pm
There was mention in another post about a fix to keep the tube from popping out of the wind port. Is this fix available? I just received my RWS and I am having no luck preventing it from popping out I am doing everything as mentioned in the instructions). There is a square piece of plastic that was part of my package. How is this to be used and is it the solution? I didn't see anything about this piece in the instructions document.
Kevin
mccork
Postby dtrousdale » Wed Feb 17, 2010 7:57 pm
I just use two little strips of electrician's tape on either side of the piece that fits in the wind port. It's not pretty, but it's simple and comes off easily.
mccork wrote:There was mention in another post about a fix to keep the tube from popping out of the wind port. Is this fix available? I just received my RWS and I am having no luck preventing it from popping out I am doing everything as mentioned in the instructions). There is a square piece of plastic that was part of my package. How is this to be used and is it the solution? I didn't see anything about this piece in the instructions document.
Kevin
dtrousdale
Postby Velocomp » Thu Feb 18, 2010 5:37 am
If you use your iBike primarily on a TT bike, we've found that a bit of crazy glue does a fantastic job of holding the plug in the wind port. The plug is pretty-much glued permanently into the wind port (though it can be removed with a bit of tugging) so if you're mounting your iBike on a stem make sure you have room to rotate the iBike off the stem without hitting the aero bars.
Postby lorduintah » Tue Mar 16, 2010 10:23 pm
FWIW - this looks like your first or second post on the BB. The BB is where most of the action takes place for support on this product line. Some comes from users like myself. Much comes from Coach Boyd, John and Travis as they all chime in when we don't have the right answers or there is something new or they cut to the chase.
You may have an honest gripe, but if you have been reading the BB while waiting for help from Velocomp and communicating on the BB, you may have gotten some pointers to help you out during the delay.
This is a friendly group here, we want to keep it friendly.
Postby NCH1 » Tue Mar 16, 2010 11:32 pm
I agree, disparaging comments are not welcome. A more constructive use of time would be to do an advanced search of the posts to see how others have resolved their problems.
Nik
NCH1
Postby gerrard » Fri Jun 03, 2011 2:42 am
These instructions say you must do coast downs then a cal ride. Is this still relevant / necessary / appropriate? Reading other (more current) forum posts suggest that coast downs are not so necessary. For what reasons should I do or not do them?
Gerrard
gerrard
Postby Velocomp » Fri Jun 03, 2011 7:09 pm
The only thing that's important with the RWS is the Cal Ride. The Cal Ride figures out the calibration of your remote wind sensor. Coast downs are not necessary.
Postby back_marker » Tue Jan 26, 2016 4:48 pm
I am trying to download the pdf, but there seems to be an issue. I've tried on two laptops and an ipad. On the laptops, I get an Adobe Acrobat alert: There was an error opening this document. The file is damaged and could not be repaired.
Could someone please upload a new version of this?
Thanks in advance
back_marker
Postby Velocomp » Tue Jan 26, 2016 5:11 pm
Thanks in advance
OK, updated and uploaded! Should work now...
Return to Installation/Usage Instructions and Videos
Who is online
